- Jun 11, 2010
- Powhatan, Virginia, United States
- WassupYa Mang?
was a "C" board in there??
Does the cap touch the meter?
Going to need to relocate those caps clamps and all further "down" and "in" on the one near the three fuses. Hopefully can cover the old holes somewhat.
Jer - how about making an adapter plate from something like 0.125" alumimum. You can rotate the clamps add holes to the plate to match the existing chassis holes, counter sink the plate and bring fasteners from the backside to attach the clamp and caps to the plate - then install the plate. No new holes required.
But yeah that'd be a great idea 'cept as I told Lee I seriously lack any tools or equipment for that task. Great idea tho!
I think I can manage with them cap clamps... they'll hold the new guys.
I built some too.. see-Lee?
I don't know what it is with this one but seems stuff just doesn't quite "fit" as it seems to be a very early model (check me Joe). Anywhoo.. these brackets ought to serve good as supports for the caps to sit on as we'll be "strapping" em in for the ride.
