WOPL pl14 board kit rev e
Minnesota
#21
More pictures would help. That small shot does not tell much.
Operator Error ! :mad:
I had the Ground wire from the fz Generator going to the the ps cap (ovdc) and/or the speaker ov
I moved the ground to the RCA Ground input and it cleaned up the wave , Cant ask for a better SQ wave? ;)what do you think of the waves?
also I don't run the RCA inputs levels very high, But when I do, should I get worried about the hi-pitch sound from the input Transformer?
Looking into the speakers next which are low Ohm.
Steve
Minnesota
#23
Hey Steve, how about some pics of the entire backwall assembly...
Joe
*Side Note*
Anyway what do you think of me sharing my personal cheat sheets here?
and I did use your Board layout as a template and added a lot text and w part# to the print, to make it easier to assemble the boards together (and a check list after each step 9not done cuz I do w/o a list ) I don't know if you would take that personal w my Procedure and Copy protection rights?
I think the forum will not be open to it and their set in their ways. but they a very willing to help :) is a big bounce here on the forum.
Thanks
Steve
*I'm always thinking outside the box*
Minnesota
#24
Joe
Have you had time to answer some of my Questions?
I'm analyzing it now.
The Original boards seem to go lower Ohms but I was pushing it w lower ohm speakers
(it also had some of this problem but at a higher volume))
The WOB board sounds good except for this problem.
What Ohms is this board rated for?
Done
1. Buzzed (Ohm) out all wires to back plane
2. when thought the doc w color code (not easy to do)
need to regroup again
3. Made wires shorter
Update - Regrouping today send pics later and list
1-Double check board components
2-Sent a lot of time analyzing the Original Phase linear drawing being wrong, (Npn side)
I'm still going to double check it I need to redlines my drawings
3- Documentation 1st on the list
Thanks
Joe
#25
Joe
Done
Thanks
Joe
What are WOB
#27
You have Copy Protection Rights to WHAT?????
You got me so confused
Minnesota
#39
Can't understand what you are talking about. Also, where is there an "Input Transformer" ????
When applying a sine wave into the amp (RCA inputs) and turn it up into clipping, I get a high pitch noise I think its from the transformer, which makes me nerves, Is this Normal?
