- Mar 6, 2022
nooo,.....you must remember your meter is also upside down....Does AC reverse polarity in the southern hemisphere?![]()
The transformer plates are varnished so they are electrically isolated from each other. Do not wire brush or disturb the varnish coating, and do not paint the plates.Hello again wise ones
It's been a while however I feel the universe was telling me that a WO upgrade must be taken slowly.
This is due to what Joe called "the shipment from hell"
Anyway my upgraded chassis and assorted bits have finally arrived. I took the large step today and removed the chosen donor trannie today and upon close inspection there seems to be what looks like either glue or flux on the plates surrounding it.
Should I try and clean it up or leave it?
PS Shipment from hell took 4 months to get to me here in Australia. Apparently arrived in Oz late November and took a couple of months to travel the last 3000 kilometres ( those that use imperial will have to work it out)
you are in the best place...with communication and pics...they will not allow you to build a crappy amp...as i was told 2 wopls ago...lolUnderstood now Lee and thanks
Yes Jim I managed to get a wiring kit from White Oak. Will that be acceptable for my build?
LoL Joe is helping me a great deal but I don't want to bother him too much so figured I would share the love
Maybe I'm a case of all the gear and no idea?
I haven't found anyone here to help me with this so here I am
this thread was started months ago...when he started posting again upon receipt of parts...i went back to reread and refresh...stumbled on this post mr. george...it does get in your head!!!I've had this song in my head all morning.
I've often thought about revarnishing the the outside of the transformers, although I haven't because mine are in good shape. Anybody tried it? Only "varnish" I've ever used is polyurethane. Probably not the proper material.
couple of mine...someone painted the transformer plates black...didnt match the other corrosion...lolReally no reason to . As long as they aren't noisy/buzzing which can indicate the layers are delaminating. I think there was a thread where one of the guys was going to re-dip it but I think his issue was his test equipment/setup making him chase noise that wasn't there.
How about spraying the transformers with rattle-can truck bed liner? That should dampen any errant vibrations... and the texture would look cool (most important, obviously).
same advice i got about painting the fins i made...I wouldn't. The transformer can put off a fair amount of heat and I would think that the liner would hold that in.
