White Oak- Phase Linear Driver Board Tester
#44
Yeah, but there hasn't been one I''ve put together since Gibsonian's that hasn't. It's when things go awry that it will earn it's keep. Just knowing whether it's a board problem or chassis problem will cut down a lot of frustration.
#45
So your board checker will test WOA and PL boards? How much do you charge for the test? I may have another PL0171 board to send your way... That should be good for about 3 board checks.
#46
It looks like Lee has wisely set up the fixture to take advantage of the uniform spacing offered only on the White Oak Board :)
#48
"It is a feature, not a bug." Joe is wisely implying there is no reason to test the PL boards, just replace them with the White Oak Audio boards...
#52
If I had designed the new boards I would be acting the same way Joe, " Dudes!!! Don't waste your time on that dinasour!"
