Looks really good there! Only one thing - on the DC protect I see those white wirewounds for the Z networks. If you still have the two 10 ohm pairs that were in there, suggest you put those back in place of the WW's.
Here's a pic from a 700 I did awhile back showing them... tie them in parallel then stand one side up, other side you may need to extend the lead a lil..
Zach, that was my fault on the standup resistors. I was so happy with the space savings I missed that it was a wirewound resistor. I now use 2 X 2.7 ohm resistors in series. I used 5 watts for a while but they were to tall. If you want, i'll send you 4 of 2 watt 2.7 ohm
Jbeckva The boards come in sheets of 10. They are scored so they can be broken apart. I should have broke off the trash piece on the front edge of the DC board. What cap did you use on the zobel? did it fit?
