Hi there,
I couldn’t come back sooner here, being on a professional trip for the rest of the week… So I moved my request from my presentation to here...
Summary of my problem : I recently bought a WOPL 400 that was sounding cristal clear at the salers place and I can now ear a 50hz noise through the speakers (from any source selected on the p-amp).....
Just a quick summary of your various propositions concerning my humming issue… :
"Flip the plug ? ": checked, no difference
"First does it hum with NOTHING plugged into the input RCA Jacks?" : yes it does
« If it is not external, I wonder what the power wire routing looks like inside. If its 50hz, it sounds like an AC mains wire is too close to an audio signal wire. If it was 100 hz, thats a sign of bad power supply capacitors. » : I put here down a couple of pictures… I didn’t see anything obvious…
« tighten the bolts that hold the transformer to the châssis » : checked, no différence
« power cable - the original wiring was two pronged and it is important to plug this in correctly. If you have a three pronged plug the earth ground should not be connected to the chassis. » : I think my cable is original, two pronged at least…
« is it a hum through the speakers ? » : Yes it is
I think I am stuck now with this issue… I seriously don’t understand what can have changed between the moment I listened to i tat salers place and my home….
Hope you have an idea,
Florian
Florian
