Seems the resistors remain good but the transistors appear iffy. You should replace all 3 with ON Semi MPSA42 devices. Do you have ON Semi originals?No Joe I did not replace any of those... I never saw a problem till I took the DBT out which then gave full 120V voltage...
I did check the resistors in circuit, all 3 on the left side come in at 132ohm, on the right side Q5 is 132 and Q3 and Q4 come in at 133ohm
Did some checking out and looks like I did order the Central A42's and 651's. Back when I started this repair when I found a known bad part I woulld order some extra stuff that may be in question as I went through the board. Looks like those 2 parts were not in stock and obsolete so I took what was available. So what happens on this eventually Joe? Will you have to go to another brand, find an ON replacement, or do a whole new redesign for parts that are available??
Eventually Ray will have to find alternatives and qualify them. Was really sad when ON Semi discontinued TO-92 production, they are the best manufacturer out there. I have a lot on hand, I stock up very heavily when EOL notices are served by the manufacturers in cases like this.
I eventually had to move before on RevD to RevE when ST Micro discontinued production on 2 critical parts on that board. I still have a lot of service stock available for that too.
