This or That ? ...
This or That ?
  • Total voters
    2
BlazeES
The Great South !
Sony Metal Master FTW !
Klipsch RF-7 Mark III
FREQUENCY RESPONSE
32–25kHz +/– 3dB
POWER HANDLING
250W / 1000W peak
SENSITIVITY
100 dB @ 2.83V / 1M
NOMINAL IMPEDANCE
8 ohms compatible
HIGH FREQUENCY HORN
8.5” square 90˚ x 90˚ Tractrix® Horn
HIGH FREQUENCY DRIVERS
1.75” (4.45cm) titanium diaphragm compression driver
CROSSOVER FREQUENCY
1,300 Hz
LOW FREQUENCY DRIVERS
Two 10” (25.4cm) Cerametallic cone woofers
INPUTS
Dual binding posts / bi-wire / bi-amp
ENCLOSURE TYPE
Dual chambered, bass-reflex — via dual rear-firing Tractrix ports
HEIGHT
49” (124.5cm) including plinth
WIDTH
13.875” (35.2cm) including plinth
DEPTH
17.875” (45.4cm) including plinth
WEIGHT
97 Ibs (44.1kg)
Martin Logan Motion 60XT
Frequency Response
35–25,000 Hz ± 3 dB
Dispersion
80° x 30°
High Frequency Driver
1.25” x 2.4” (3.2cm x 6.1cm)
Folded Motion XT Transducer with 4.5” x 2.75”
(11.4cm x 7cm) diaphragm.
Mid Frequency Transducer
6-1/2” (16.5cm) aluminum cone with cast polymer
basket. Sealed chamber format. Rigid structured dust
cap to reduce cone break-up modes.
Low Frequency Transducer
Two 8” (20.3cm) aluminum cone with cast
aluminum basket. Non-resonant asymmetrical
chamber format. Rigid structured dust cap to reduce
Sensitivity 94 dB @ 2.83 volts/meter
Impedance 4 Ohms. Compatible with 4, 6, or 8 Ohm rated amplifiers.
Recommended Amplifier Power
20 – 400 watts
Crossover Frequency 400 & 2,200 Hz
Cabinet Ported
Components
Custom air core coil and low DCR steel laminate inductors.
Polypropylene film capacitors in series and low DF electrolytic capacitors in parallel. Tweeter
thermal/current protection.
Inputs
Custom 5-way bi-wire tool-less binding posts
Weight
66 lbs. (30 kg)
48” x 11.4” x 14.4”
BlazeES
The Great South !
The K's win by 31lbs & 3hz.
Do you prefer ported speakers?
Both speaks have rear ports. And everything I've ever owned has been ported. I don't know if I'd call that a preference though.
My only experience with horns is way too dated to remember.
That's why I posted the other thread about peeps impressions about AMT tweets vs. horns a while back.
The K's are 90 by 90 dispersion, so from a purely spec standpoint - that seems a better way to go...
Mike (mkuhl2000) and I are planning on hitting the Klipsch factory in Hope soon. Would be cool if I can demo those bad boys with some of my own CD's.
I also have a friend that manages a Magnolia Center and I'm waiting on him for some info. The prob is, he's on the West Coast, so I can't demo any good stuff - no Magnolia showrooms in this neck of the woods...
Bradrock
Alton Mo.
---I run with Scissors
If I was riding around down there I'd stop by Bob Crites place too, just to check his stuff out & maybe talk a bit.
Mike (mkuhl2000 ) and I are planning on hitting the Klipsch factory in Hope soon. Would be cool if I can demo those bad boys with some of my own CD's.
While you are there demo some Jubilees....
BlazeES
The Great South !
Yeah, shit he's in Hope too ain't he?
His website says Russellville, which is to the north-west of Little Rock. Past Conway, headin' to Fort Smith on the I-40.
Hope is down to the south-west, towards Texarkana... so hours apart essentially.
