STV-4H diode
calman46
MA
Do these diode get "leaky" ? On a restored SX 980 one diode will bring the idle current to 6mV but other diode it will go down to 20mV. Its the diode I swap them around. I can set the bias and it appears to hold when testing .I wondering if the diode is on verge of failing . No replies at AK . Thanks
nakdoc
Nashville, TN Music City
highly biased
I just had an STV-3H with one diode shorted internally. The symptom was no bias on that channel. The STV-4H has 4 series connected diodes inside. Rather than leaky, it probably has the same failure as mine.
Arizona
I just installed a new set of STV-3H in a Sansui.... They were toast. The brittle wire on the other one snapped up next to the body..... Hell of an invention eh???
Thanks, kinda pricey. The last ones I bought were in Germany 8 years ago for 6 bucks ...the Spec 2 would be grounded without the STV-4H...
