- Jan 14, 2011
- Gillette, Wyo.
Now that's funny Scott....
The black lead is on the GND test point. The red lead to the meter is contacting the transistor on the board. The resistor is just there for the purpose of connecting between the output and ground test point when I finally put power to the unit. I just soldered the resistor onto a couple clips for easy attachment when I move on to the next step. Only one clip is connected, the one on the output test point. The other is hanging free (I, just now, completely removed them from the unit and nothing changed in the readings). UPDATE: I just went out and took another reading, after doing what the paper actually says to do, "Remove the one wire to the upper left backplane 6-32 screw by removing the securing nut and floating this wire in the air," and the resistance disappeared. Duh! So, am I correct in assuming it's okay to move on with the procedure now?
Okay, now I got me a problem. I was just tightening the transistor screws, just to make sure they were snug, and I heard a pop when I just touched the last one. I knew what it was, but not why. So I pulled the board loose to take a look. As the photos show, one of the screw sockets pulled away from the board. And trust me, I come from a mechanical/machinist background. I NEVER over-tighten fastners. In fact, on something like this, that doesn't move or receive vibration, I only go light, finger-tight. Plus, the spacer, as you can see, is in place, such that the whole thing doesn't make sense to me. I checked the threads in the socket and they're fine. So it didn't bind and twist it off. Obviously this is only a support socket for the transistor. It doesn't carry current (right?). So I'm guessing that I can just glue the thing back in place and put it back together.? If so, what sort of adhesive should I use? Hot glue? JB Weld? Polyrazmataz?
View attachment 31191 View attachment 31192 View attachment 31193 View attachment 31194
