really?
K-5BLAZER
las cruces nm
square body cause I dint want a plastic 4x4
#22
it is a car audio thing on higher end amps if you look really close you would see threads sticking out past the nuts unnamd.jpg better pic
it is hard to find good cable examples this is the best I can do they plug in and then screw down Asv73uTNVE_-Jkv6I8IIRcnx6LCZhFB0A8r1JgdLZTX_fePZkLzkdpIxwmJva2GddtVXRRXV6_88M2_2eeD_trzY-2VIQC...jpg
#23
They were used a lot in the 90’s; maybe still are.
Tiffany BRAND jacks, not STYLE jacks.
Another solid, gold plated jack.
K-5BLAZER
las cruces nm
#29
Next you'll want the chopstck cable elevators and oxygen free oxygen. Get a hobby and keep yourself tethered to the earth
no I do not think so while I do belleave in SOME cable stuff like NEVER use CCA I own a line condissioner OFC is a lie it is not possable to get all the air out
#32
You can get nearly all the oxygen out. You have to melt it under vacuum. Even better in a hydrogen furnace, since the hydrogen “gets” the oxygen to make water.
But it’s not copper color any longer...
#35
I found these several years ago and have been MORE than pleased with their quality. $20 per piece is not TOO bad and have had zero issues. Plus, the fit is perfect.
K-5BLAZER
las cruces nm
#38
that is a killer price do they come in gold plate with carbinfiber bands to match my banana plugs and fork/spades. they do not have to but it would be cool if they did
https://www.parts-express.com/1-4-t...carbon-fiber-and-brass-shell-2-pair--091-3616
I forget what one of these 3 I got
https://www.parts-express.com/nine-...crews-and-carbon-fiber-shell-2-pair--091-3612
https://www.parts-express.com/expan...on-fiber-wrapped-brass-shell-2-pair--091-3614
https://www.parts-express.com/bfa-s...on-fiber-covered-brass-shell-2-pair--091-3610
K-5BLAZER
las cruces nm
#40
as for getting this thing I do not know or trust any one eles to do it. I apalojise in advance for this if comes out sounding bad or coming of as an ass-hole or insert your own term(s) but I got Qs about lots of shit and just want answers or opinions. again sorry
