But it's necessary for the age and not for noise .I'm with Paul. Since doing this on my first 700 which was basically stock but recapped, I've tried to do in on most everything, preamp or power amp. I can typically hear the difference.
In this case l generally saw loss in path , hum , short and so on .
These are faults . IMHO .
Ciao
Marco
These do, Mouser P/N 598-103MWR630K. At the 630VDC rating, the AC rating is 220VAC; more than adequate for use across the rectifier terminal pairs which should never see more than 200VAC.
Datasheet attached.
Funny you picked this one: A suitable alternative to the film would be Mouser ceramic disc. P/N 72-AY2103M61Y5VS63L0
I have been using this AC-rated ceramic capacitor across the power switch for a long time. P/N 72-VY2103M63Y5US63V0
It is a Y2 300VAC rated capacitor, and the price is $0.48ea. I honestly can't tell what the difference is between the two.
Don, between the two of us we have both seen our share of blown caps. I appreciate your insights. BTW, I just ordered 100 of that ceramic cap you called out. I did the research and found that the cap you mentioned has straight leads (my cap had kinked leads), and your cap is 2mm smaller.Edit: This was posted befored I saw Marks' response above which makes this post somewhat redundant.
I bought and install the P/N 72-AY2103M61Y5VS63L0 for the bridge rectifier 4x. will this also work for the power SW?These do, Mouser P/N 598-103MWR630K. At the 630VDC rating, the AC rating is 220VAC; more than adequate for use across the rectifier terminal pairs which should never see more than 200VAC.
Datasheet attached.
Yes, the cap you specified above is a safety-rated 440VAC cap, perfect for across the contacts of the power switch. Are you using both sets of switch contacts, if two sets are available?I bought and install the P/N 72-AY2103M61Y5VS63L0 for the bridge rectifier 4x. will this also work for the power SW?
Thanks . I bought a bunch of these because of this this thread , not to long ago, since the other ones were out of stock, so I bought the 2nd kind since they were in stock at that time . I do have the 2-sw Power-sw , So I will use them. I know this Brand is in everything related to input power,,,,Yes, the cap you specified above is a safety-rated 440VAC cap, perfect for across the contacts of the power switch. Are you using both sets of switch contacts, if two sets are available?
BTW, these caps are not in stock at Mouser until Feb 17, 2023.
