That is not factory Lee...some prior owner kludged that in there...Thought I would get the input/output jacks sorted out, keeping the relay instructions cloase at hand (and yes have those 8 fiber washers safely stored away). Cannot believe this is factory, they are all 1/4" jacks soldered to a copper substrate that floated above the fiber washers.
And another view
Now with them separated for a close up.
And finally the output jacks. Worth noting there were a pair of 1N4004's paralleled nose to tail between the copper ground plane of the input jacks to the ground buss on the output jacks that you can see at the top of the picture above.
If anyone has a image to share of a clean installation after rework that would be awsome.
The potentiometers cleaned up nicely and now track well so that is done.
Convert to two RCA input and bypass the switch altogether. Run the inputs directly to the control board with high quality RG316 coax.After studying @Hexis22 thread on the original 700 build It seems that is an original copper plate. Now any reason why not to replace all four rca jacks along with the switch or should i convert it to a two jack assembly?
Lee the input on the control board is direct coupled. It is recommended that you direct couple the RCAs into the input of the control board. Any decent preamp has a large coupling cap on the output. For reference, every PL400 ever built was direct coupled and came from the PL factory that way.Like this without the switch (snipped from the schematic)?
Have not yet received the boards etc from Joe so cannot study them to see if there are coupling caps on the input lines. My usual go to for coupling caps is a 1uf MUSE with a paralleled 0.47 ecq which would be easy enough to either direct wire to the input jacks or at the board input connection point. Interesting side note, a friend is finishing up a very lengthy and thorough restoration and upgrade of a Dynaco ST-400 and we are in a discussion at the moment on how to quell the Frankenstein light dimming that occurs when those twin 15,000uf caps first charge up. Sort of settling on a SL32 inrush limiter thus using him as a test subject for the PL-700 with the same size caps.
Correct.If I understand the forum consensus - - - Direct wire the rca jacks (one set), eliminate the volume potentiometers (leave them in the front panel for show), trim the copper plate to fit and block off the bottom two and round switch hole with plugs for appearance. Correct?
Does no harm either way, they are only essential in columns 2 and 4 as you correctly note.Busy reading threads as I wait for parts. Seems to be different thoughts on the predrivers. This amp had rca410's on each of the left channel output bank and motorola 7439's on the right channel banks. Question then becomes use one rca in position 2 and 4 counting from the transformer or use the rca in each of the 4 bottom positions as I found it?
Since not much else to do started playing with various led ideas blatantly copying where other members have gone before
Plus it lets me fool around with my bench top power supply, various banana leads of destruction and multiple sizes of rubbers.
After all I am sure I read somewheres in the forum rules we must practice safe mounting of any LED's.
