Thought I would get the input/output jacks sorted out, keeping the relay instructions cloase at hand (and yes have those 8 fiber washers safely stored away). Cannot believe this is factory, they are all 1/4" jacks soldered to a copper substrate that floated above the fiber washers.
And another view
Now with them separated for a close up.
And finally the output jacks. Worth noting there were a pair of 1N4004's paralleled nose to tail between the copper ground plane of the input jacks to the ground buss on the output jacks that you can see at the top of the picture above.
If anyone has a image to share of a clean installation after rework that would be awsome.
The potentiometers cleaned up nicely and now track well so that is done.
