- Mar 6, 2022
offset??
bias??
persistance is an admirable asset...
bias??
thats the guy that advised you on q1 thru q4...etcOn order ty
offset 3.1 & 3.3 mvdcoffset??
bias??
Your faith in me kept me from giving up Gene thank you sir for giving me the support and confidence to keep pushing onward.told ya you could do it!!!
i keep throw away speakers just for testing...My celebration is cut short seems my 8ohm resistor bank doesnt allow me to test loaded however it does drive a speaker left channel that is , now what i thought was a working right channel now distorts as i turn up input so going to check protection circuit i replaced Q9 but dont have another Q8 1304 pnp. will continue to update so Joe keep an extra WO14 i might be calling lol.
Gene i did get to full power and set bias both channels to 350mvdc , offset still 3.3,3.1
Don I look forward to getting my speaker relay board , I think i need new input post they seem a little weak holding input rca center pin?
you are a good man charlie brown..No...no cap in your dummy load.
The 1304's and
05's are germanium and read much lower than a silicon. After you pull aleg of D9 and D10 can you go full throttle with no distortion?
If you keep having problems with the 04's and 05's let me know. I have quite a few nos TI's...
Yes until clipping no load I'm afraid to try with dummy load but drives speaker ok well I don't want to blow them up got my relay board coming soon.After you pull aleg of D9 and D10 can you go full throttle with no distortion?
Will do but they should closer to the same hte right?If you keep having problems with the 04's and 05's let me know. I have quite a few nos TI's...
Ok well I checked diodes and don't see any other issues.HFE? ya mean? Dont know if there are enough left in the world to get matched sets. I've never matched q7,q8..
This is what I made up as a load bank should work right?View attachment 75793
