Try hard to NOT have any caps in the direct audio path.
3 rules to live by...
Or a bipolar (BP) or nonpolarized (NP) electrolytic, or two electrolytic capacitors back to back, for example: negative to negative, then the two positive connections become the non-polarized version. Also, the capacitance divides in half, I believe.If you MUST use an electrolytic in an audio path
Capacitance does divide in half. If you put 2 electrolytics back to back then be very sure to parallel with the film cap. Other than low ESR type caps (and those are not really very good either, they are just better) electrolytics do not have great high frequency characteristics.Or a bipolar (BP) or nonpolarized (NP) electrolytic, or two electrolytic capacitors back to back, for example: negative to negative, then the two positive connections become the non-polarized version. Also, the capacitance divides in half, I believe.
Am I correct here, Joe? Then again, why would you do this if it violates Rule #3?
I never make snarky comments, except where that cranky old oil man, Lee, is concerned.
