Bubba, I would think that on this forum, collectively, we could fix anything, broken hearts and cracks of dawn notwithstanding....
Have you seen Dawn's crack too? I tried to cover it up!
Well, it's very promising when a guy finishes your sentences when speaking of the problem..
Thanks Ron. Now I need to find the proper weight oil to fix the cueing arm. I had tried 200,000 but that didnt seem to work... Might have to get 4 or 500,000. There is no dampening left to it. So you have to be very careful dropping the tonearm.
I found some online for my PL-71, and just went downstairs to look for it. Do you think I could find it??? Nope.
I think I got it from these guys...
http://turntablebasics.com/silicone.html
For $10 it's worth a shot. I think shipping was around $4.
Alternatively, there is silicone gear oil sold at hobby shops for RC buggies that is 500,000 weight.
Dave
Yes, you have to remove a set screw on the left side and remove the cylinder and piston assembly from the tonearm base.The local hobby shop is where i bought the 200,000. It was all they carry. I have been on that site before, maybe ill have to go ahead and get a bottle from them.
Have you actually fixed the damping? I could not for the life of me get any of the 200 to seep in via the plunge hole.
No problem, Sir! As I recall, the top of the cylinder has a little round cap that will come off and allow you to fill that way. Just fill it up and the excess will come out of the little breather hole when you cycle the arm. You do have to be careful because the round cap on top will want to pop off until the fluid level is stable. I don't know if I did this the right way, but I couldn't find any advice or documentation anywhere to help me. Good luck!Thanks for the advice. I knew I was doing something wrong. I also wondered about that tiny little hole on the bottom.
