- May 1, 2013
- Australia
- Those who enter the man cave will get WOPLed
VRLA's (valve regulated lead acid) are notorious for thermal runaway. I had a set do that in our battery lab a few months ago. The valve opened on a couple cells and spewed like a geyser. Stunk up the building. Fortunately the rack is on a concrete floor.
Following your advice, I will keep the batteries as a backup to run the fridge and lights only, they are almost at end of life and have done a lot of charge cycles. Power failures are not common here, but its handy to have a backup when they do occur. Lucky nothing bad has happened during charging as they would charge on a timer when I was at work. Now I know the potential of thermal runaway, I can be more careful about it.
I am going to stick to running the stereo setup of that dedicated 15 amp circuit and furman power conditioner. Is there any potential issues that could arise running the preamp and other components off the same circuit, or should they be separated?
