PL 400 renovation cost
GMEAD
#61
Scott, I assume you are talking about the venerable PL400, and not the improved PL400 Series II. The difference in sound between a stock PL400 and one completely rebuilt with White Oak Audio (WOA) parts is phenomenal. The posts above have merit, many think the PL400 is not worth rebuilding. However, I have done the full PL400 rebuild many times and I can tell you, IT IS WORTH IT! Most people do not need more than 200 Watts per channel anyway. With the rebuild you will be getting 250-300 Watts per channel. The difference in sound quality comes mostly from the new Rev G1 Control Board that replaces the original Phase Linear control board that has a faulty design, poor layout, and components that are 40-50 years old. The difference in increased dynamic range comes from the new WOA main Power Supply Capacitors with almost triple the reserve power capacity. The difference in lower noise and distortion comes from the new WOA Backplane Boards that eliminate the vintage point-to-point wiring on the back of the amplifier. The difference in sheer power that will knock you over comes from the 16 new Output Transistors that have much more gain and are more closely matched due to modern manufacturing methods. You really need a pair of decent speakers when you get this upgrade.
I really like the sound of the PL400, it is smoother and less shrill than its big brother, the brute, the PL700. I have both and I can listen to the upgraded PL400 all day; the upgraded PL700 (1000 Watts) is perfect for scaring animals and small children, after a couple of hours listening to live thrash metal bands like Metallica, AC/DC, etc. I'm done.
But its your call...
GMEAD
#62
As new as I am to these amplifiers I have to say that that is what I noticed about the 400 in comparison to the 700s I picked up. It just sounds better to me and I love the big VU's. My speakers have horn mids and tweeters so shrill is the last thing I need. My listening space is rather small and 200+wpc is enough headroom and more than enough power for my needs.
Deano452
#64
I have a series one PL400 the previous owner installed leds on the Cylons , it has the new 15000uf 100v caps but I was thinking of purchasing the new boards but I'm a little confused do I buy the backplane board kit , the dual mono control board kit the bridge rectifier and snubber kit and what else ?
VSAT88
Phenix City Alabama
Like my BlueTooth ?
#65
Probably about it besides new output transistors. Don't see how it can be a series 1 if it has LED cylons. Series 1 should be a 4 fin (heat sink). Joe/Lee or one of the other more knowledgeable fellows will chime in and help you soon for sure. Welcome to Phoenix!
Deano452
#66
Yeah sorry it has the big VU metres my bad , I have the output transistors I bought extra doing an old Adcom in anticipation. Thank you for the welcome .
VSAT88
Phenix City Alabama
Like my BlueTooth ?
#67
Have you pulled and tested the bottom row transistors yet? The drivers? They should be different numbers than the rest. Can't remember the numbers right off the top
VSAT88
Phenix City Alabama
Like my BlueTooth ?
#68
Hell, that might not even be relevant considering you are buying a new main board IDK. Tomorrow Joe or one of the other guys will let you know. You may want to start your own thread.
