Phase Linear 700 Series II Clair Bros Serial Numbers
Clair's have machine screws in the covers not sheet metal, but if it has had a White Oak Chassis installed, it would also have machine screws. Yes Clair's have steel chassis.
Do the 400's use the same transformer as the 700?
Oh so I already have a piece to build a 700!! :wink: the 400 parts amp I have is a 4 fin one but the transformer in it is the type in the 8 fin amp the rectifier and caps attach to the transformer not the side
No, different.
both of my 4 fins are that way, I believe its common.
The transformer from a 400 will not work on a 700, matter of fact 99.99% of it wont
Not that common. Most 4 fin units had chassis mounted caps and bridge rectifier.
The later ones had the die cast cradle just before they moved to add the extra HS fins.
And the PL400 transformers are NOT the same as the PL700 transformers. No way, no how!!
Has the rail volage but not the KVA's.......
Mine has the White Oaks chassis, so a steel chassis isn't a foolproof identifier.
Yeah, the White Oak chassis is a whole different animal....
Try putting a WO top cover on anything else...............no go......
If ya don't mind a little overhang.....
You people get up early back there....
Just updated the serial number list. Greg is now current. I need to go through my papers and update this more. It's close though.
Here is a few.
8663 Perry WOPL
9457 Gary WOPL
9462 Albert WOPL
9463 Charles WOPL
9465 Perry WOPL
9466 Perry WOPL
9467 Perry WOPL
9468 Perry WOPL
9471 Casey WOPL
9472 Paul WOPL
9473 Trev WOPL
9474 Greg WOPL
9475 Greg WOPL
9478 Gary WOPL
11386 Robert WOPL
11994
11998 Will WOPL
11999 Robert WOPL
12067 Paul Stock
12072 Dennis Stock
12073 Dennis Stock
12074 Skip WOPL
12075 Skip WOPL
12077 John Stock
12081
12083 Ron WOPL
12314
12317 EBAY Stock
12319 EBAY Stock
12321 John Stock
Last one is just coming off the bench. Serial number 8663 going to the bay for sale tonight.
