- Mar 6, 2022
i think so...only one was entered into their system ..i am sure tomorrow they will update the other...
They really liked the 8 finner...i think so...only one was entered into their system ..i am sure tomorrow they will update the other...
joe,
why should i upgrade to your chassis....what do you have that stock chassis dont have??
when my stuff all gets here...i think i will desire another chassis....
i have a box of nut plates and tinnemans left over from the airplane days....but, you have addressed that....Multiple reasons Gene but primary reasons are that PL should have done all these things in the first place...peruse the attached.
https://www.facebook.com/AmericanPickers/videos/phase-linear-amp/1121945288250769/I happened to be visiting a friend at the hospital when one of those "pickers" shows was on the TV (sorry I am not familiar with those shows as I rarely watch TV) - they were admiring an 8-fin 400 and reminiscing about Phase Linear's history of building killer amps. The bargaining went back and forth, but the amp looked to be in very good shape - $275 took it.
i watched many of those shows....about your toys and stuff....
i have the same situation....i new wopl....an 8 fin and two 4 fins....I have one of Joe's replacement chassis for a 700, but I'm not sure which one I'm going to use it on. One of them had a torn ear from rack mounting... That one either has a new chassis or an ebay posting in its future.
What is the general consensus - for my first 700b build, is it easier to use the existing chassis or the WO new and improved chassis? Wondering if it's better to start with a blank canvas or a dirty one with outlines. Ultimately I'm going to do both, but just wondering which one should go first.
I don't know. Perhaps a output transistor is wounded and cross conducting. You did build it back up row by row and checked bias stability with each row? If not, then that's what I would do.thank your mr. george....
well ,,,. i was watching all of the voltages...etc....letting the machine run without inputs/outputs....
ran 30 to 45 minutes....then i noticed the dcp relay cut out....took dcp out of circuit again....
i disconnected and waited for the caps to discharge...maybe 5 or 10 minutes....put the dvm on left output (now disconnected from the dcp) and chassis gnd....
i repowered ....dbt acted normal...bright then dim....and for about 30 seconds all was fine....8 or 9 mv....as i am watching the meter....then the dc voltage start climbing on that left channel again....kinda goes up in stages....was the negative voltage rail again....
if you let the caps discharge....the cycle repeats....
q8 and q5 were both changed....q8 was in a repair kit i bought when i got the cap kit for the 400....
q5 i took off of your board....
in circuit...they both check the same as the other channel....i am definitely missing something....
what is the minimum i can power on with....just the bottom two rows on left side???I don't know. Perhaps a output transistor is wounded and cross conducting. You did build it back up row by row and checked bias stability with each row? If not, then that's what I would do.
something is breaking down....takes about 30 seconds for the dc to show up.....i am not convinced the q5 on that used board is not the culprit....I don't know. Perhaps a output transistor is wounded and cross conducting. You did build it back up row by row and checked bias stability with each row? If not, then that's what I would do.
