- Mar 6, 2022
and check for shorts to gnd....before i repower...i will adjust my nutdriver accordingly...
many thanks...again...
are the fully complimentary output chips bolted to the heatsink on the chassis in the wopl upgrade ???I just use Duct Tape (The sticky kind)....![]()
Hello Geneare the fully complimentary output chips bolted to the heatsink on the chassis in the wopl upgrade ???
and plug into the updated backplane??
Lookin good Gene!!
ok...was just looking for this...i am about ready to do this mod...i dont understand what latch up is???If you are going to keep the 400C and recap it, replace C8 with a 470uf, 25 volt electro cap. That will improve the bass rolloff point. Also read this..
https://forums.phxaudiotape.com/thr...-up-tendency-in-phase-linear-amplifiers.2307/
In your case, C6 that they arer referring to on the Pl14 board is C8 on yours...
really trying hard find another 400 to gut...made offers on a few....lots of 4 fins on ebay...He's getting some 96's..
but, i trust you know ... when you posted this...i told one of my recap sellers to toss in a 470uf cap...but, forgot i needed two...
this will also replace the one i reversed....and dont trust any more....and i got another 470uf cap with the pl200 recap kit...
should be here very soon....i need to go back and find which diodes you said to put back to back but reverse one...
got a pretty short memory....
please explain latch up...when/if you have time....
thanks!!!!
95/96s run just as hot as the originals Gene. Watts is watts...no cheating physics.really trying hard find another 400 to gut...made offers on a few....lots of 4 fins on ebay...
too expensive....of course at any time i can upgrade mine.....i think extra cooling can be easily accomplished....
but, if the 95/96s run cooler....why bother....a 4 fin would cool effectively....or get one of those fans recommended by sniff...
i really would like to have both....
i have time....i would like to compare....and do some graphs...
just having a good time...
Hello Gene
It is when you walk into a room on a mission to do something and then once you get there, you forget what your mission was...
That is latch up![]()
Hello Gene
