- Mar 6, 2022
i have all instrument bulbs to led conversion on order...be here next week along with a new knock sensor...was just thinkin...i knpw thats dangerous, but i cant help myself...i have a 2 way autel code reader...bought it a while back to keep the dodge tip top ..I'd fix the check engine light and the sensor or wiring.
I don't see a check engine light as a annoyance.
I see it as a built in diagnostic indicator that's helpful. I really like modern fuel injection and coil packs versus the old carburators, chokes, and points.
With a good code reader and the Internet for reference, it's relatively easy to figure out what needs replaced to clear a code.
already did the standard tune up...plugs wires dist cap rotor..Nice 4 wheeler, every ranch needs one!
Could be a dirty MAP sensor. They do need cleaned with the appropriate spray occasionally.
May have the wrong plugs in it. Use the brand and part# of the plugs Toyota recommends.
No fancy so called high performance plugs!
AC Delco Iridium where called for, old AC Delco Double Copper where called for, or whatever Toyota calls for, probably a Denso product.
Service the PVC valve or whatever crankcase ventilation system it uses.
Lots of things will cause issues and not throw a code including minor vacuum leaks.
will go through more sensors...already did the standard tune up...plugs wires dist cap rotor..
great idea...added to list!!!I’ll second the vacuum hoses. They may be attached, look and feel fine but have leaks where they connect.
lololol
she just wants to trade...you know...an eye for an eye!!!She only has eye for you…
