- Jan 14, 2011
- Gillette, Wyo.
Same behaviour when populating a row at a time?
changes were noted mr george...Gene, perhaps the pin outs on the plastic transistors are a issue. Pin outs changed between early and late GES93, GES97, and others.
Also note the specifics in the first Service Bulletin 1-76 regarding transistor type.
Taken from Don's site. Thanks to Don for making this available.
Ungor one of them $25 China component testers and it’s done a good job of identifying transistors...Perhaps time to get a Sencore transistor tester.
i have one...i use it often....not sure if its the one you refer to...Ungor one of them $25 China component testers and it’s done a good job of identifying transistors...
i am sure it is functional...just need to finesse the bias. ..i will look into the transistor tester...if i get one like yours. .i think you will guide ne through the work .Gene, none my 400 S2 dual primary transformer wiring looks like yours. No black primaries or secondaries other than the black buss bar ground wire. And your chassis has the sticker and no drillings I could see for the six screws that hold the Cylon meter sub plate to the chassis.
I'm thinking it truly is one of the first export 400's.
Think about all the people who tried to fix it in the past and didn't know what they were looking at. Glad you got it sort of working, and I'm sure you'll eventually get it spot on.
If you do pursue a old school transistor tester, I do really like my Sencore TF-151A. It is slick, and such a joy to use. The TF-151 is a cluster of point to point internal wiring, best avoided, while the later TF-151A uses a circuit board, dirt easy to recap, restore, and align.
Used the Sencore to test the plastic transistors on the modulation board of that Boonton RF Generator. Was easy to test for Beta and leakage, and it has higher current settings for power transistors that a battery powered tester can only rudimentary test. Yup, it plugs into the wall and has a transformer. Later!
keep your eyes open for me mr george....i think i will invest...i am sure it is functional...just need to finesse the bias. ..i will look into the transistor tester...if i get one like yours. .i think you will guide ne through the work .
thanks for sharing mr george
still need variac too!!!keep your eyes open for me mr george....i think i will invest...
i think (even though i dont know bear s**t from apple butter) you are on the right track....If it is a PL14 board you are playing with Gene and cannot get the bias to go low enough, it is often that the bias circuit is the culprit.
You can try increasing R19 which should be a 680 or 470 ohm resistor on the PL14 board to 1K instead. That will allow extra base current for Q6 to help it come closer to saturation and bring down your high bias.
well, you both have me convinced....neither would mislead me...They don't get any nicer than this. And it's the "A" model with the circuit board.
https://www.ebay.com/itm/1957054507...NB_S8D7Qg2&var=&widget_ver=artemis&media=COPY
