ABebar
I'm literally here for constructive criticism. I truly appreciate the feedback and suggestions. I'll crank up my iron and reflow these.Adam, make sure your solder joints at the bridge are not cold. A couple of them look sketchy where the solder is not flowing into a meniscus on the bridge tab, rather it is a blob sitting on top of the tab. Very high peak currents exist at these connection points. Trying not to be critical but these should be improved up. You will need to leave your iron dwell on these connection points longer to fully heat the tab and let the solder flow. These tabs are designed primarily for Faston connections. When soldering, you have to overcome the thermal mass that exists here.
