enoyes12
- Feb 14, 2014
- Phoenix, AZ
- No, I won't turn it down but you CAN go away!
Are they the half moon shaped ones toward the bottom of the case?
See thats the problem I couldnt see them thru all the mold. What should the meter be set to?
Bumping this photo to the top...
Red meter lead to black wire. Leave it there. Then put your black meter lead on the red wire, take a reading. Then move your black meter lead to the brown wire, take a reading.which probe goes where?
ok right side red wire 670, brown wire 670 left side red wire 578 brown wire 520
Thank god you guys know how to do this and can communicate this so I can understand. Good thing is once I understand how I rarely forget.
Nav, you need to do this more often, very methodical of you. I have a tendency to bounce around a bit which probably confuses the less knowledgeable (like me).. Very consise directions too. Nice Dennis...
What else would cause the bias to not adjust?
Now that was funny and just thought it was cause you were smart
The place by me only carries NTE brand. Is there an equivalent or what are the parameters of the 2n5088's I can pick some up tonight. If I can adjust the bias with the 2n5088's What does that mean?
