Phase Linear 400 issue help!
enoyes12
Phoenix, AZ
No, I won't turn it down but you CAN go away!
laatsch I've had the amp sitting here plugged in and noticed the left side heat sinks are warmer than the right, feels about twice as warm. not hot just noticeably warmer on the left
R38 is a 10 ohm resistor (brown-black-black) that is between the base bus bar and the emitter tie point. Positive lead on the base side, hegative lead on the emitter side. Be sure it's powered down and PS caps bled. If you slip with the leads in there when it's on it's usually an output or two that goes and Q8 or Q9, and Q7, Q10 and a couple diodes. Not worth it to hurry on that.
enoyes12
Phoenix, AZ
I also noticed a hum when I reversed the plug so I cut a notch in it on the hot side so i don't plug it in upside down
You don't have to get on the resistor leads, put a lead on the base bus bar and that big wad of emitter resistor leads...
enoyes12
Phoenix, AZ
ok i think I found it. left side is reading .465 and the right is reading .162. I tried turning the pots but no change
