- Jan 14, 2011
- Gillette, Wyo.
Check these out Dennis--------http://forums.phxaudiotape.com/show...s-Phase-Linear-400-Series-II-Quasi-Comp/page7
one little tip. To hold the faceplates vertical, take some 3" poly pipe , cut some 3-4" length pieces and slot the to fit the plate. that way they can be vertical and leave a lot more room to work the chassis.
Good advice Larry with the baby steps. I have the new WO controller board and LED board but I think the next change will be adding the dc protect board as I don't want to damage any speakers. I'll give it some more time before adding this board but we do want to practice safe audio. The LED board will follow and then we'll see what is next.It is a PL. Lee and I went through this with my PL. I like the sound of mine w/o the mods. Not knocking the WO at all. I have never heard it. LOL Try going with some nice caps in the signal path. You can swap them to the WO mod. Just baby steps. When I bought the BGs they were a lot cheaper. There are some very nice caps out there. If you really want to go crazy. Read up on the Shotky diodes. Interesting reading. I was thinking of doing it but I didn't. Wonder if they can influence the sound? Since it is only going to be yours there are other tricks you can try before you swap. I'm an efficiency nut. Give them the least amount of work. Heat is bad. Are you coming out of a 120 volt power supply? Not the wall. My amps draw some power. If you can keep it stable and see what happens.
Digital cameras are hard to catch a transient with.
They have!Those 901's should be able to soak up all that 400 will put out.
