Chris Cables
Saved for latah.
and chist on a bike - the asking prices of CR4's on ebay these days! this popped up under your ad in the suggested feed:
https://www.ebay.ie/itm/235498893621
Saved for latah.
Which model?I've got some kind of Nak with stuck meters I grabbed cheap.
I need to either fix it and sell it, or just sell it.
Seems an o scope is somewhat needed for this hobbie. What would be a good used scope for a hobbyist? I've used them so there wouldn't be a learning curve involved.
And maybe an audio signal generator too...
I found a schematic, but I will contact them for a better copy.You might try asking them.
https://www.bkprecision.com/support
Oops...make that 4 broken pots. Appears the seller cleaned this unit after testing it and snapped the mounts. Should have retested but chose to send me a broken generator. Then had the gall to accuse me of breaking them. Anyway, foundAnybody have a B&K 4011A schematic and parts list?
Mine needs repair. Got 2 bad pots that need replacement.
