I use both a Tek TDS350 (digital) scope as well as a Tek 2225 (analogue) scope, mainly for cassete deck refurb/repairs.
Both are great, stable and reliable but I defer to the TDS350 mostly as I like its' 'autoset' button which means bringing up waveforms that fit to the screen is a cinch! (gowon, call me lazy, I dont care
The 350 also has math functionality which makes waveform differences easy to visualise (v handy for azimuth corrections)
I had to swap out it's noisy af ball-bearing fan with a quieter one when I got it but now it's almost silent and I can leave it switched on for hours without any noticeable background noise.
Sometimes I whip out the 2225 to verify reuslts on the 350 if I think I'm getting spurious results from things. Good for measurement redundancy therefore.
I use a Wavetek 75A arbitrary waveform generator which is fine, accurate and adequate for what I use it for if not the easiest to set up.
I do need to get it set up permanently on the bench somewhere at some point though...
a quieter fan, pilfered from an old busted PC power supply
Its' usual operating position, slides in and out from under the bench
and does Lissajous, for all that's worth
Azimuth bang-on for a CR3E. Triggers off ch1 which is why ch2 looks 'smoothed'.
Now to finesse the L/R amplitude...
