- Jan 14, 2011
- Gillette, Wyo.
Close to 1000 Ron...
Quick reply before hitting the sack...Lee and Jani coming soon, gotta get some sleep...
I've searched and read many threads, a WOPL 1000 is a PL 700 series II? 700B? Power moved up from 350wpc to 500wpc?
I like the Clair Bros look Perry!! The fact that they were used by Black Sabbath makes them very special indeed, after I talk with Lee later today, I'd love to chat with you very soon bud!
AWESOME Joe!!!!! That's the higher end of low bass frequency right? What is the DF at say 50Hz?
Tis harder to damp a woof than a mid or tweet...
My 700's put out the same power of approximately 450 per channel in stock or WOPL set up. The out put is a function of Rail Voltage.A stock 700 will generally yest between 450 and 480, depending again on rail voltage. Those are max out figures, not continous ratings...
I know that Lee, DF is only applicable to bass frequencies, just trying to get a handle on the DF average across the bass frequencies and if Joe's design in anyway increases the DF factor. I also asked if there was a way to increase DF factor in a build. I know some Crowns have a DF average of 4000 or more and there is no way I believe any Crown amp is better then a WOPL
How do you measure DF anyway? Is it dependent on the power supply only?
I wasn't aware of how important damping factor was until the F's.....and they ate the Spec's lunch. And I didn't realize that the difference in damping facto would make that much difference even on the K's, but it really does. Even the Bryston, SAE, and all the rest that have been through here, don't hold a candle to a WOPL.
I was backwards thinking the DF was lower as the frequency lowered.
Joe, so bigger speaker wires preserve DF?
