My First WOPL 400 Series 2 Build
Dnspy007
Tennessee (Gods Country)
#62
Nice work. Yer gonna love the 400 II WOPL. I listen to mine daily and I have my 700 II WOPL sitting in the rack since I finished it about Jan, I put an hour on it and I haven't fired it up since.
I am going to wire up the 700 II WOPL and use it for the bottom end and use the 400 II WOPL for the high end. Been to busy to get that done but it's going to be miserable hot and humid today (heat index of 100) so maybe I'll get motivated and do it when I finish testing this Carver C-4000 this morning. No yard work till tomorrow (a high of 72, go figure). I think I may build another 400 II WOPL IF...... I can find another 400 II Faceplate like the one I got from Glen with holes in it for a power switch and display switch. Or, I can cheat and just slap a 700 II faceplate from Joe and say to hell with it. Get your's going, yer almost there.
Thank You, For kind words Sir.
With all the good reviews on these Amps after the WOPL builds, I'm pretty sure I'll Love....Right now, Just hoping this things gonna work when I get it done. If everything goes well this build, I have a couple of 700 ll's, Planning to do the Full WOPL treatment.
This heat can make a man want to stay inside. Thank you for that idea.. "No Yard Today". I believe I'll continue on with my build....
#63
Have faith, you have a crazy awesome Tech Support Crew and Joes directions/guides will get you through this all right here on this site. Plus, you do great work and it shows. Carry On.....................
Dnspy007
#64
Bottom row installed....... Initial Test..... No Shorts from DC ground or B+/B- rails, No shorts to Transistor Cans
Power bring up with 10k jumpers ....No Shorts, No blown fuses, No Smoke, Voltage present at B+/B- rails also, pads 11&12, 0 volts at R/L outputs.
I'm at #21 on the Backplane Instructions so, I guess it's time to wire up the Control Board. Any Advice or helpful hints will be greatly appreciated...
Thanks Guys
Dnspy007
#66
Control Board installed....No Shorts, No blown fuses, No Smoke, No shorts to Transistor Cans, Voltage present at B+/B- rails also, All pad voltage close to safe mode bring up chart, 0 volts at R/L outputs. Noticed a drop in voltage. I take that as being normal, Due to installation of the Control Board and its components. Not really sure, This being my first attempt at this type of build.
Thanks for looking............
#67
Now doesn't that look much more professional inside than it did originally? Wait till you hear the sound it produces...
When you add the control board, you get the bias loading which moves the rail voltages down slightly.
#70
Joe is generous with the wire lengths going from the Backplane Boards to the Control Board to make sure you have enough. You can certainly trim them so that the bottom cover does not come into contact with them. Completely optional. Measure twice, cut once!
Input Jacks look great!
#72
Yes, because there is a discharge path now through the "Fused" and "Unfused" rails.
However, I always measure or just install a 200 Ohm 10W bleeder resistor between both caps, just to be sure. I have seen too many sparks...
You are smart to measure!
Dnspy007
#73
Thanks Mark
I intend to straighten the wiring after the Transistors are installed, and all test are good. I left them alone, Just in case I had to remove Control Board..
#74
I install the thin Nylon washers under the Control Board and under the two Retaining Nuts because I have to remove/replace the Control Board often during a rebuild. And it helps on my Bench Test Mule Amplifiers that I use to test Control Boards for customers. I should install wingnuts!
Vintage 700b
Wisconsin
Fabricator
#76
Got a question before I install 2nd row of Transistors. Is it normal for the caps to discharge at this stage of the build?
Reading a few minutes after powering down....
Yes, the caps will discharge. As Mark mentioned that he does, I also use a 200 Ohm 5W bleeder resistor and (2) small alligator clamps wired into each end, and after installing a row of T/O's I discharge the caps quickly. I made two of those small bleeders, and I use them on everything, A/C repairs, welding machine repairs etc. They are handy, and sure beat shorting a screwdriver across the cap !!!! (I've seen guys do it !!!)
I believe you will find this noted in Step 13 of the "Bring Up Instructions, although it may be in a different location for the 400 bring up:
" 13. Remove AC power and use a ~200 ohm, 5W resistor to discharge the 2 bulk caps down below ½ volt."
Dnspy007
#77
Yes Sir,
I made one before starting the build, as per the Instructions. Mine doesn't look quite as sexy as yours. I didn't even think about shrinking it I like it..... I'll have to do some modification...Thank you for the Pic.
Dnspy007
#78
Finished install and Testing of the 2nd row of Transistors. No Shorts, Blown fuses, Smoke, Shorts to Transistor Cans, Voltage present at B+/B- rails, 0 volts at R/L outputs, All pad voltage close to safe mode bring up chart, Checked Bias, hanging around 0.348v still in the perimeter.
Rockin' on to Row 3
Vintage 700b
Wisconsin
Fabricator
#79
Rockin' on to Row 3
You're getting close...........you will be making incredible music soon ! :D
#80
The Bias reading will probably not change much, now that you have two rows of Output Transistors installed. The real Bias check is after all your Output Transistors have been installed and the amplifier has been producing some serious music for thirty minutes or so - it will be nice and warm.
Or in Lee's case about two minutes at Mach 10 through the Klipschorns!
