- Jan 14, 2011
- Gillette, Wyo.
They are Q8,Q9.
I will definitely post my results of the PL 400/2000 in progress and will give some updates on the Citation 16. Right now I have completely redone the two driver boards with new caps and diodes/resistors as needed. Also put some new pots for bias/offset. Upgraded the power caps and updated the bridge rectifier with some new fairchild diodes. The heat sink assembly has been done over replacing the various resistors and caps. The last issue I have is one of the channels dead and I have narrowed it down to bad outputs. Just have to figure out which ones and find some replacements. After that it should be ready for some testing.
The 16 is rated at 150 WPC but it is definitely a big 150 watts and is no slouch to the PL 400 but I am sure once I get the 400 WOPL'ed it will kick its butt big time. After that I will have to get another Citation 16 to run dual mono and if I recall that will give me around 500 watts/channel!!
My Dad has a PL 700 series I. That baby is what got me hooked on Phase Linear. He is super excited about my progress on the 400 and wants me to tackle his unit afterwards. He is using it to run a set of 4 Bose 901's which is ungodly loud even without cranking it up all the way. It needs a good overhaul to update before going big.
Haven't looked into it much but where I can I grab some info on upgrading/modding the PL 700 series I??
You can upgrade the amp board and add DC protection, but no way I know of yet to make it fully comp like you are accomplishing on your 400.
You can take a Ser 1 and make it fully comp but it takes a complete rewire of the backplane..
Today I populated both backboards for the 400 with all wiring. Looks like I am about ready to tear down the amp and start the building up process. One mistake I have made is the bias transistor I soldered in and didn't realize it should have been left long to bend down to fit into bracket. Question is do I need the transistor to fit into the bracket or can I go without as now it is too short to bent into the bracket?
Seems pretty fair deal to me, looks to be in perfect condition.
The rubber pads simply cannot conduct heat as efficiently as properly assembled goop and mica, it's just easier.
