Oldskoolfan
Well, before I place my order to WOA I thought I should check the transformer outputs first. No sense having a beautiful rebuild that can't be used.
Under no load conditions as in Nothing connected to the transformer, my voltages seem a little low
DC = +57.5 and -57.4 from rectifier with 5.7 vac out across the positive and negative output.
AC = 125.7 across the input to the rectifier.
The lo voltage AC reads 5.7vac which seems acceptable.
Input to Transformer is 122.5vac
These voltages are read with the power caps removed. Will that make that much of a difference? Or do I have a bad rectifier?
