- Jan 14, 2011
- Gillette, Wyo.
Almost forgot about this little cutie. Last time I used it the meters would not settle down. It was an open 47 ohm / 1 watt resistor in the floating ground section. Easy fix. Calibrated with the ATS-1DD... don't know if it can double as a voltmeter calibration but it is good to 5mv in the generator department. Cald good at 1 volt, 10 volt, and 1 volt at 400 hz and 50k hz. I think it will be just fine..
