- Jan 14, 2011
- Gillette, Wyo.
And took the AC neutral run from out of the lower bundle and run it up north, got er figured out.
Correct Lee. That neatens it up an makes it strain relieved.Finally figured out what you did under the heatshrink. You co-joined the shields and lenghtened with the black wire...
Can the AC going to the switch(faceplate) be broke out and bundled by itself? Or was that what you were referring to?
Black wire comes off the fuseholder , enters the loom, goes to the switch, comes back from switch inside the same loom exits at the fuse holder and continues on to the accessory receptacle..
No gold star and a pat on the head??![]()
Thats better.......![]()
Had to do some switch surgery. Ine of the tabs on the Direct/Normal coupling sweitch had one of the tabs "rolled" out so the slider nubbin was cockeyed. Took the switch apart relocated the tab with some strategic bends and popp[ed it back together. It now has that "snap" of a properly detented switch. Lee 1--amp --0
A world famous amp derailed by a 3.00 switch, indeed what were they thinking..
