And the other trick is shown here Jer. Skipping the bottom slot allows you to install the pre-driver transistors for initial bring up while still having the heat sinks securely in place. You MUST use nylon washers to do that bring up trick. Otherwise you will just blow your rail fuses if you use metal washers.
Now he tells me
		 Maybe a test drive? Sounds like fun! Wish I had the time and knowledge to do it myself.
 I think I will stick to the hack saw at home. If i need to cut a buss bar, I'll take it to work. We currently are using 3/4" x 8" copper bus bars with ten 1/2" pre drilled holes. Two rows, as ground bars for a monsanto project. About twelve panels. I'd love to have something like those bars sitting around at home. I could definitely find a use for them I'm sure.
