- Jan 14, 2011
- Gillette, Wyo.
Re: Jerry's " ONLY ONE IN THE COUNTRY" Phase Linear 700 Thre
also test point for setting bias, but you knew that.
mlucitt said:I found the cause of the distortion on channel A. I had a open resistor that I had not seen before. This is R39 and it normally supplies B- bring-up to Q12 and sets the quiescent base voltage for the negative half of the output power transistors. Am I close because that was a stream of conscienceness?
Here is what I found. My PL700B is now happily running in pre-driver mode. I will install the output transistors tomorrow.
Mark
