- Jan 14, 2011
- Gillette, Wyo.
allrighty.................
mlucitt said:Pull the outputs and leave the drivers. It is about a 100 Watt amp with just the drivers installed and this will confirm the problem is pre-driver/driver, or outputs.
laatsch55 said:Good Job Jer!! Makin music??
laatsch55 said:Pretty sure the flat tops went quite a ways at that voltage. Put you loads in some cold mineral oil, Dry ice, Liquid N2, whatever ya got handy. Then ya can romp on it!!
BTW--I came up with 589.
mlucitt said:I like the one on the right, I dn't know why...
Make sure the .27 Ohm resistors are negative biased and the .33 Ohm resistors are positive biased, just look at the schematic and you'll see what I'm talking about.
