- Jan 14, 2011
- Gillette, Wyo.
One of our basic tools is a funnel/stacker..
The finger lift is broken off of the SME headshell... I found a replacement headshell but didn’t like the £296 price tag... found these guys on crapazon which will mount to the cartridge bolts... figured worth a shot. Also ordered an anti skate test record for final set up. Just another thing to add to the long list of jobs when I get home... View attachment 42824
Yeah they’re not worth $20 for sure but I didn’t see any on eBay any cheaper. Also by the time I get around to making one I’ll have forgotten about the $20! Any I saw on eBay were $30US for one. If I wins sure it would fit, I might have gone with the under mount. As it is the over mount doesn’t cover the SME logo and I’m wondering about the cartridge to headshell contact with that between them also???For what you get, that's expensive. Last year I ordered one of same for an SME headshell. It seemed like dozens of Chinese vendors (or the same one dozens of times) were offering those on E-bay for two or three bucks and same for shipping.
I've still yet to install mine - still in the plastic bag.
Granted, I'm in BC and took about a month to get. I could not bring myself to spend more than what I did for a small piece of metal like that. It only cost pennies to make in the first place.
The one I got goes underneath the headshell therefore the V bend. The picture you posted looks like it goes on the top. That works and I have an SME headshell where a finger lift from a Hitachi (or something) headshell was installed that way. Doesn't look too strange.
Now you’re talking. Being aluminum it would be simple enough to make a set of dies to bend them to shape consistently. Something you smack with a hammer or attach them to a pair of snips or vide grips...Someone on this forum should have access to a water jet cutter and some aluminum stock, say .0625" (1/16") and then we could all have one for a few pennies.
I can hardly see the cantilever even with my glasses on...Those get you in the ball oark but stylus in a modulated groove is different than a blank disc.
Observe the cantilever from the front while it plays and fine tune it such that the cantilever stays straight, and not favoring one side or the other.
I used the Rega glass platter for set up and then fine tune by eye. Currently set at zero...
Figured I’d post this in the turntable section... If you’re new to this project, I am working on (I believe) an early Prisma. I bought it from my Uncle and it was working aside from needing a belt and stylus, (possibly the stobe needs work?) however for some reason he removed the lid and replaced the original legs with rubber feet.
I am in the process of having a plastics fabricator make a reproduction cover for me and I plan to fabricate reproduction legs. Attatched are some factory drawings I’ve come across but I wondered if anyone here has a Prisma that they would post some photos of and maybe even some measurements?
I am after the details of the leg mounting arrangement and how the thumb screw leveling is fabricated. Also details of the prop rod and hole location as I plan to machine a replica.
I am away at work so for now I am gathering information and details required to proceed with the lid reproduction but also wondered if someone can identify the tone arm? I know it’s SME, but what model/series? The cartridge is Shure V15 type IV, I have a spare Shure stylus but am told it was dropped and bent :/ so I ordered a new replacement from Jico. Did I make a mistake there or are their products reasonable quality?
Thanks guys!
Hello and welcome. Nice score! Yes I did have a new dust cover made by Hank at P&A plastics in Hamilton Ontario, Canada. https://paplastics.com/
He did a very nice job of it. I’m quite happy with it. Michel was receptive to making a replacement cover also however the UK is a long ways from me and I can only imagine what they would charge. They were helpful with information and small parts. Belts are readily available and the same across most of their turn tables. I think the belt was $30?
let me know if I can be of any help.
Yes, mine is in use now and working flawlessly. I still haven’t reproduced original style legs but it’s otherwise complete. What parts are you missing? Yours looks very complete by your photos but then again I’m on my phone and can’t blow them up real big... looks like your sweep brush is even intact, I had to source a horse to repair mine!Thanks AS I appreciate your reply. This will be a slow process I'm sure trying to source parts, if available etc. If I can be of any assistance to you with your table, let me know.
Is yours up and running now?
Thanks,
Dennis
Oh, just in case you didn’t see it back in the thread, are you aware of where the coarse speed adjustment pot is? You must remove the switch cover and expose the motor top, there is a small hole through the top of the motor case (maybe 3/16” hole”. Insert a 1/8” slot blade screw driver very carefully until you engage the potentiometer. I made this adjustment with my fine pots set in the middle and have had no issues since. (Mine was running slow).Thanks AS I appreciate your reply. This will be a slow process I'm sure trying to source parts, if available etc. If I can be of any assistance to you with your table, let me know.
Thanks,
Dennis
