- Jan 14, 2011
- Gillette, Wyo.
What was in it??
The last time I was in my storage unit, about a week ago!When is the last time you saw one of these?
View attachment 37970View attachment 37971 View attachment 37972
Found this when I unboxed the amplifier, a true time capsule, completely unmolested. Have you seen a PL like this?
I meant an upside down label... Is that what you saw in your storage unit? I've never seen one.The last time I was in my storage unit, about a week ago!
I missed that one. The crop may have been harvested that day. I think Ed has some stories on that.The last time I was in my storage unit, about a week ago!
PL400 assembled with WOA Control Board and Fully Comp Backplane boards, only bottom row of output transistors installed. No control of the bias voltage on either channel - the bias voltage measured on the Control Board is .014VDC on L and R regardless of the position of the bias controls. I'm using 2N5088 for the Q6 transistors. Using a DBT. Checked for proper voltages from the power supply, good 15 VDC and edge connector voltages on the Control Board, checked for proper bias wiring from the control Board to the backplane boards, and verified the Q6 transistors are inserted correctly in the backplane boards.
What would be some logical troubleshooting steps that I have overlooked?
Joe, yes the bottom row of output transistors are in the appropriate locations. Rail fuses measure good and + and - 83VDC is in the right places on each channel of the Control Board.
Never had bad bias voltage on both channels before.
yup bias dialed right in on the test fixture for both channels if that is the board you are using.Yes, followed the instructions to convert it. I am using the Control Board that you checked for me a few months back. I know it works...
And the collector to emitter voltage for each of the Q6 bias transistors measured at the Phoenix connector test points is?Yes, both the +80 and the -80 are on the Control Board for each channel. DC offsets are .003VDC and .012VDC.
