ksrigg
OK...I have (almost) everything in hand and am ready to start...I actualy have replaced the light board with the led board, and painted the bezels for the meters. I haven't soldered the board back in yet..
So what is the next task. ..I know to epoxy the sleeves with the asbestos looking wrap on them...then what is next. Is it safe for me to cut the old PCB out of the amp? I really need to be able to get it out of the way to replace the power cord and the caps, etc...I took some pics of the wiring, but don't know if it will help or not as the new layout looks different anyway..plus I have a broken fuse holder, so might as well replace them all..
When I get to replacing the transistors, are they soldered in place? Can't really tell..
Also, I know I need to replace the Bridge Rectifier. This one still has the original 25A one. I ordered a 35A and hope it is enough..
Got the variac to work, after learning they will blow a GFCI plugin...Lesson learned..
If MCM had not screwed up and left my solder station out of my order, I have a feeling I would be way farther into this thing. I really want to have the new iron to go at the BR...as I remember that solder is pretty uncooperative...
Sutton
Sutton
