roccus
Great!! will be glad to get them to get this show on the road thanks for letting me know
Everything in your order shipped this morning Ray.
Hi Ray
Can you get a better photo of the wiring in the area of the phono jack inputs please?
Get the soldering iron fired up Brother!!!
Your kit came with 2N5088 bias trannies, use the 2N5088 holes, not the 3403 holes. And yes you will need to add about 5" of #20 wire soldered to the B+ feed on the upper right corner of the right backplane for the B+ feed for the DCP....
No, just one #20 wire on the upper right B+ feed on the right backplane......the DCP requires one AC feed and one DC feed.....
Correct on the shells and tips of fuses. Wire according to Joe's assembly instructions. When doing that, there is NO connection to the upper right B+ pad, the upper B+ pad is used for the DC feed on the DCP....
The one nearest the heatsinks is B+, the middle one is B- and the one near the edge of the chassis is AC Mains. The label on the heatsink then matches and your wire lengths will work out properly then.OK there are 3 fuse holders here does it mater which one I use??? I do understand about the upper right B+ pad I will only use it for the 5" wire for the protection board but was wondering what color for that wire you guys are using?
