First Time Building PL400 BP Rev B
#21
So moving along in the build I made a pretty dumb mistake and accidentally added R6 to one of the boards and am now short a resistor R5 on the other board.
Thinking I should just snip it and try to solder in the best as possible or order more resistors?
Thoughts? You guys have been a huge help so far, thanks for everything.
Just neatly clip the resistor out of the wrong location and put a wire jumper in the right location. R5 and R6 are 1 ohm resistors and are just used as jumpers that happen to look a touch better than a wire jumper does. Find any 1/4W resistor, cut and form one of the leads off of it into the jumper you need. On RevC backplanes, the 1 ohm resistors added to that revision in other locations are for more than jumper purposes but the R5 and R6 you are dealing with are just jumpers.
#22
Way to crowded on that board to be spraying molten solder. Solder splash would be a disaster if you didnt find all of it .
MarkWComer
Gaston, SC
#25
I have had good luck desoldering by getting it molten and blowing it out with an air gun. I don’t think “canned air” (or Perriair from Spaceballs) would work.
Sometimes takes a couple tries but it works. Feels nice when it splashes on you too.
Be careful with that- you could blow a splat of solder where it shouldn’t be, cause a short circuit.
#26
Exactly what happened when it hit my arm. I totally short circuited.
But in my case I got away without doing further damage to whatever it was. A digital panel mount volt meter I think.
I did try splaying some fine copper wire strands to wick it but that didn’t work.
Phantom Lamb
#27
Finished populating first board last night with components. To clarify, I should desolder R6 and can use a straight wire for R5 on the other board?
Still no luck in fishing that darn resistor out of there, maybe need a smaller tip on the soldering iron?
