How does he get anything done if he always has a phone stuck to his ear???
HUH?
HUH?
Add me to that 'saw phone circle!Seems we all have phone conversations with him, indeed, great guy to talk with..
Glen is very generous with his time and knowledge, he just helped me finish a little project. He sent me some parts to upgrade the D500 and was concerned that I didn’t have a way to safely discharge those monster capacitors, so he sent some parts and walked me through building a discharge box. It worked perfectly but after seeing a picture of his DBT, Capacitor discharge combo, I felt like I needed to up my game.Add me to that 'saw phone circle!
We've been working on my D500 project, or more correctly, HE's been educating me on all his knowledge gained from years of rebuilding these rare beasts. "Drinking from a fire hose" would be the correct analogy!
And up your game you did..Glen is very generous with his time and knowledge, he just helped me finish a little project. He sent me some parts to upgrade the D500 and was concerned that I didn’t have a way to safely discharge those monster capacitors, so he sent some parts and walked me through building a discharge box. It worked perfectly but after seeing a picture of his DBT, Capacitor discharge combo, I felt like I needed to up my game. View attachment 66445View attachment 66446View attachment 66447
I was thinking the same thing so I found thisBut wouldn't there be a drop across the rectifier? Mess up that precisional cabliration n shit.
Yes, there will be 2 diode drops =1.2 volts. I don't think accuracy is critical in this application. The intent of the meter is to know when the caps are discharged. A couple volts doesn't matter.But wouldn't there be a drop across the rectifier? Mess up that precisional cabliration n shit.
This is definitely on my list to get done. You guys are always teaching me something new and bit by bit I am getting a great education. I am eternally grateful.Yes, there will be 2 diode drops =1.2 volts. I don't think accuracy is critical in this application. The intent of the meter is to know when the caps are discharged. A couple volts doesn't matter.
See you are ready to try a rebuild on your own . Just listen to yourself. lolThis is definitely on my list to get done. You guys are always teaching me something new and bit by bit I am getting a great education. I am eternally grateful.
I appreciate your confidence in me but I am not sure I am ready just yet….See you are ready to try a rebuild on your own . Just listen to yourself. lol
Ok no rushI appreciate your confidence in me but I am not sure I am ready just yet….
Put me down as a beta tester. IMHO the best phono preamp was found in the David Hafler DH-101 Preamp.Good news: it may be available commercially soon.
The DH-101 used very good transistors in the circuits...Put me down as a beta tester. IMHO the best phono preamp was found in the David Hafler DH-101 Preamp.
Wasn't Erno Borbely had something to do with the Halfer gears?The DH-101 used very good transistors in the circuits...
