Lee, on the LED board installation, it tells me to hook up the 8 wires on pads 1-16 which emanate from the amplifier. My amplifier has no wires emanating from it. The LED board has the pad number and a color of a wire that should go to it. There is nothing showing what I am supposed to hook up. I tried to explain this to Joe but he is not looking at the same thing I am. Please look at the schematic and the assembly instructions (Page 17 step 12 which says): And remember, I do not have these wires.
I also do not have the attenuator knob, volume knob or anything emanating out of the amp. I see no mention of meter drive signals coming from the amp.
12. [ ] Using the 22 AWG wire strippers, strip 1/8 to 3/16” from the end of each of the four meter wires and the eight wires that emanate from the amplifier electronics.
13. [ ] Using your soldering station, carefully solder the 4 meter wires to the upgrade LED Light Board at the locations labeled PAD8, PAD9, PAD12 and PAD13 as shown below in Figure 12 and
Figure 16. The illustrations show these entering from the solder side (non-silkscreen side) of the board and being soldered on the component side (silkscreen side) of the board in order to mimic
the assembly of the original light board. It really does not matter which side these wires are soldered on so you can reverse the entry and solder point if you desire (if wiring to PAD6, PAD7,
PAD10, PAD11 it is preferable to solder these wires in from the silkscreen side of the board).
a. PAD8 = RIGHT METER
+ (if your PL700B was originally wired to the PAD6 location,
you may use this location instead)
b. PAD9 = RIGHT METER
– (if your PL700B was originally wired to the PAD7 location,
c. PAD12 = LEFT METER
+ (if your PL700B was originally wired to the PAD10 location,
d. PAD 13 = LEFT METER
- (if your PL700B was originally wired to the PAD11 location,
you may use this alternate location instead)
14. [ ] Using your soldering station, carefully solder the eight amplifier wires to the LED Light
Board at the locations labeled PAD1, PAD2, PAD3, PAD4, PAD5, PAD 14, PAD15 and PAD16
