- Jan 14, 2011
- Gillette, Wyo.
Dan...After reviewing the build BOM, R42 on the backplane boards should not be populated. We had tried both populated and unpopulated versions and the unpopulated is now the official version. It had been prior to your amp being built, but the brain was not engaged that day, and subsequent days for that matter.
The consequences if having R42 in is higher frequency distortion products and asymmetry in the drives. Very easy to cure. Leave R42 in and solder a cut off lead around the R42 in place. You will have to drop the driver board out of the way to get to the left channel R42. Be sure the big caps have bled off.
