Here's a problem you face as a restorer of thie stuff. As can be seen more than half the phono jacks are soldered in crooked. Sooooooooo, do you desolder, straighten and resolder or just clean and go????????? Now consider, most customers will regard ANYTHING not up to spec as YOUR failure, not the factory's. After you have had your way with em, Thank goodness that doesn't happen here very often. Beins my name will be on the inside of this, they will get straightened along with a lot of stuff you just can't charge for and still have a good reputation out there.
