speakerman1
- Jun 12, 2010
- OZONE ALLEY MARS (Visitor)
- Wasted Days and Wasted Nights
What are you doing up?
Larry
Larry
speakerman1 said:http://www.answers.com/topic/sulphonation" onclick="window.open(this.href);return false;. HMMMM I think 2 things are missing for this to happen. You may have dissimilar metal corrosion or just oxidation. Why are you using D-5 and D-100? D-5 is a 5% solution. And D-100 is a 100% solution. I'm just wondering. The D-100 should be all you need and not much of it for sure. I pray there is no benzene or sulfuric acid in your components. I'm not trying to be a smart allelic at all. I just see words I have never seen before and I wonder. So I look them up. It does expand my vocabulary to which I'm thankful. Keep using the big words please.
W hat happens in a pot is not simply corrosion, lots of other suff involved there. Exactly whatI don't know, but I will.
Larry
HUH?laatsch55 said:speakerman1 said:http://www.answers.com/topic/sulphonation" onclick="window.open(this.href);return false;. HMMMM I think 2 things are missing for this to happen. You may have dissimilar metal corrosion or just oxidation. Why are you using D-5 and D-100? D-5 is a 5% solution. And D-100 is a 100% solution. I'm just wondering. The D-100 should be all you need and not much of it for sure. I pray there is no benzene or sulfuric acid in your components. I'm not trying to be a smart allelic at all. I just see words I have never seen before and I wonder. So I look them up. It does expand my vocabulary to which I'm thankful. Keep using the big words please.
Larry
Galvanic corrosion? When two dissimilar metals are in contact with each other..Just add a little moisture.laatsch55 said:Iknow that. Sulphonation in the classic sense doesn't apply but it's similiar enough to get an idea. It's like corrosion and eletrolysis combined.
Thats not quite what I meant.He just isn't a computer savvy person and feels intimedated by the keyboard.That' just it Dave, no confrontation here, and if there is it won't last long
Lee about the brittleness. I have rewired houses built in the 20s and 30s. The copper was still soft. The big words sort of hard for me to spell. So I will leave that part alone. LOLlaatsch55 said:Does solid wire get brittle after 30 years ? That's my only gripe with it. So, you must have wire wrap tools.
