fitz43
fitz, it was the one Joe recommended the DV-983H.
Thanks. One day I'll replace my carousel with something better.
The 2N5087's did not work out for a sub. Temperature co-efficients must have been different, went way squirely under a load. I have thusly swapped those out with a pair of 2SA979's a 100 volt rated part, compared to the 50 volt 2SA798, which run at 66.5 volt. The 979's lack the gain of the 798's we'll see how it affects performance.
Lee you should find out why you have 66.5V. That is a problem that needs to be fixed. It should only be about 28V
Nothing you can do except use the correct device here Lee. The Spec4 has 66+ volts across the front end by design, the Spec2 has ~28V, much more normal.
Just use the rigth transistor, the 5087 gave you odd results because they were breaking down. The 798's are in the same boat. The 2N5401 looks like the only reasonable device for this location.
Looking good Lee, Maybe one day I will send my Spec4 in for some TLC.![]()
The KSA is a better choice Lee, get the F gradeHow about a KSA992, Or Zetex 795A??
